Given how little is acutally known about how the remote feature works in HomeCenter. I have today added ACL's in my firewall to drop any traffic from my HC2 units and internet
Because i will assume that HC2 has bash.
Very good point.
Another thing they should try not to copy Apple. just like dodgy upgrades that don't work for everyone.
I've set up my router to block all external traffic to and from the box as I don't have a world of trust in Fibaros security settings... Only issue is the lack of weather forecast - and it is an irritating function anyway as i can't choose the weather provider.
Guest deraaij
Fibaro uses indeed bash
I hope they don't think we are posting our HC2 back to Poland for an update.
robmac with a touch of grit in his teeth
/emoticons/default_icon_wink.gif" alt=";-)" /> unusual!
I've seen a guy in a white van with polish plates roam around our neighborhood at night lately... I wonder if that is their delivery guy who is trying to figure out which houses have a fibaro system...
If the bash vulnerability "shellshock" now suddenly is a reason to keep your HC2 off the internet then you're probably lost already.
As mentioned above, the "Remote access" feature is poorly documented - but when you just think about how it works... You should not want it:
  • - You enable "Remote access" in your HC2
    - Your HC2 connects to a unknown remote system with unknown levels of security
    - You use your portable device app to connect to this unknown remote system
    - Your connection to the unknown remote system proxies you into your own HC2...
    - The only way that can work is when there is a permanent tunnel between your HC2 and the unknown remote system.
You think that was ever safe? You have absolutely no idea what else goes over that tunnel. Given that your HC2 is basically a Linux box, someone on the other end who has control over the unknown remote system could be running all sorts of code on your internal network by abusing your HC2. You would not even notice it...
I haven't blocked my HC2 based on shellshock - I blocked it as one of the first things when I got it - as I have no idea how the remote access works... Looking at how the app worked, I could only imagine that it would be extremely simple for even the most amateur of hackers to gain access to the system.
My awe at how simple it was to break into the box even without connecting monitor and keyboard also didn't help in my trust in the Fibaro security.
Today we will post statement about shellshock
What I don't understand is how the HC2 is able to connect to the remote server. Does it work through a port that is enabled anyway (80 is presume then?) or does it use another port? I asked this question a couple of months ago, but Fibaro didn't give an in-depth reply, just saying that disabling remote access would be sufficient.
I guess to block any unwanted access completely I would have to install a firewall?
Most routers can block access to the WAN from a specific IP or MAC-address. So unless you have a box from your ISP that you can't control, you should be able to simply deny the HC access outside the confines of your a LAN. Your user guide for the router will most probably have a guide how to do that.
Guest mhn
Your firewall is by default open for traffic from inside to the cloud. Any program can make a "tunnel" by starting from inside.
The normal way to do it from Linux is to make a SSH connection from inside to the company server and use that connection for traffic both ways. So I guess (not know) that's what Fibaro does.
Regards
Morten
Regards
Morten
Would make sense as the box has ssh enabled.
You are making a very big assumption here. Anybody who takes security and firewalls serious knows that this is THE biggest mistake you can make. When configuring a firewall the first rule to put in place is to block all traffic regardless of source or destination. Nothing goes in or out unless explicitly allowed...
You are right though - when you take SOHO firewalls into account, the vast majority is setup to "allow all outbound" unless explicitly dropped, which is the wrong default setting.
Anyway - not really on topic. I'm curious to see what Fibaro has to say about the Bash / Shellshock vulnerability.
Martijn.
Guest mhn
Martijn.
I have set up firewalls for a living for a very long time.
/emoticons/default_icon_smile.gif" alt=":-)" /> When anybody use them, it's possible to make an SSH connection out without any problem.
But I am just gussing about Fibaro.
Now i have started writing.
/emoticons/default_icon_smile.gif" alt=":-)" /> Dalle1985: The SSH you see is the demon. For what I am writing about HC2 will use a SSH client.
Enough off topic from me.
Servers that handle our remote access connections are safe from Shellshock-type attacks. To ensure highest possible level of security we were carefully monitoring situation regarding this potential soft spot in software. I can assure you that no attempt of this kind of attack took place and all latest updates needed to protect our system from future ones were performed. Hence there is no need for shutting off communication ways to or from our controllers.
Does the HC2 itself use bash (I suspsect it would), and if so is there a plan to release updates that patch bash?
HC2 uses Bash indeed, however the way our controllers connect with remote servers ensures immunity from external attacks. But to make sure every entry to system is properly protected, we will soon issue patch with all necessary fixes. When it comes to HCL, security hole that was lately detected in Bash does not apply to it at all, since it uses different shell.
Thank you for the clarification
