Linked Device - Heating & Heating Panel questions
If I connect for example a Danfoss Valve, it shows up as a device on all interfaces and I can manually change the setpoint in the room (on the device).
There is no such interface for linked heating devices. So - can they only be adjusted with the help of Heating Panel zones? If I recall correctly it's still not possible to adjust heating panel zones from Fibaro mobile applications.
Also - when using Heating Panel zones - do they adjust setpoints on all thermostat devices in the selected room(s), or only on the "main thermostat device" for that (those) room(s)?
12 answers to this question
Heating panel can only set temperatures for linked devices and danfoss in selected room. Also linked devices are not visible in any other way than rest of modules.
    Thank you for the information.
    Does Fibaro treat the older and the new Danfoss valves the same in this regard?
    How about the Secure SRT321 thermostats? Are they supported by the Heating Panel as well?
    What if there are several Danfoss valves in the selected room? Does the Heating Panel change the setpoint only on the "main thermostat" for the room, or on all thermostats (valves) in that one selected room?
    All version of Danfoss devices should work with heating panel. If more than one is present in room linked to heating zone, all of them will be set to desired point. Secure SRT321 and Horstman HRT-04 ZW thermostats can also be integrated in heating panel.
    Perfect. Thank you.
    It would be nice if we could set the temperature for linked devices manually (without the heating panel) too etc.
    lukas.polivka, you can always use manual option from heating panel.
    Not from mobile applications.
    lukas.polivka, maybe use virtual device to make a PUT request to heating panel?
    Maybe. As the last resort. It would not be very nice.
    Thank you for the suggestion though. I guess it would even work with HCL, just using plain HTTP request without any Lua?
    lukas.polivka, That should do the trick, since this is ordinary PUT method. I attached example of such device, used for changing global variables. Just change content of arguments and path.
    IP of device: 127.0.0.1
    Port: 11111
    Enter
    fill the field with your credentials in following manner: login:password (e.g. admin:admin).
    But if you want to use manual mode, you need to adjust timestamp in string that is send, hence in HCL creating some pre-defined devices for different settings in given days is probably better idea.
    Dear j.nowacki, I love the idea of your virtual device and I´ve just downloaded it! I have a pre-devined variable named "Alarm" with three values "on/off/part". I want to change the variable through your virtual device but I thing I am doing something wrong
    /emoticons/default_icon_sad.gif" alt=":-(" /> Can you please help me out? Here´s my code (String for HCL):
    Hey j.
    Can you tell me how to integrate secure srt321 in hearing panel?
    It is working normal, I can change temp on termostat and in HC, but I'm not able to chose the termostat temperature as room temperature and I can't chose it in linked devices.
    I tried on HC2 and HCL without any luck.
    I saw the guide how to do it, I follows step by step but they can choose it as room temperature, I don't have it there. How can I control the heating from heating panel, if it won't use termostats? I can turn on and of boiler, but the termostats will show wrong value right?
    I noticed that after updating to 4.032 my linked devices are not always responding to tje setting in heating panel.
    I think it is caused because of some "none" settings in the temperature dropdown. At some points of the day I do not want to change the temp and therefore I selected none.
    This worked well in the older version, but now sometimes the device hangs and it is not turned off resulting the room to get hotter and hotter (yesterday it was 28 degrees in my bathroom)
    In the mobile app I can see that the device is on and the temp setting is showing 0 degrees with a room temp of 28 degrees.
    Now I have filled in all temp switching points to see if that makes any difference...
