12v roller blinds
eg1l
Hi.
I'm planning to purchase some rollertrol 12v motors for my blinds.
I'd like to use the roller shutter 2, but it can only handle 230v.
Which module should I use for my project. I would like the finished
project to work just like it would with a roller shutter module.
If this is not possible, are there any other motors (230v) that is recommended?
If you do not need positioning of the blind, installation from attached file will work well. All you need are two double relays with a 230V coil. If you decide to use AC motor, any 1-phase, 230V AC powered one should do the trick.
  • Positioning would be nice. Looks like I have to research some 230v motors.
    Anyone have some to recommend that is not too expensive?
