RGBW and the different lumen on rgbw led strip problem.
Hello.
I really like the Fibaro RGBW dimmer but i have a request.
All LED strip manufactures have different lumen specs for the R,G,B and W channels.
So for an extended feature i would like a min and max setting for each channel (RGBW) so
we can "calibrate" the led strip to get perfect white ex when on 100%
Today we can calibrate min and max setting for all channels but as i said, a min and max for each channel would be a really good feature.
Could this be possible or is the dimmer limited in hardware?
Thanks!
Guest gembrain
  • 3 weeks later...
    Really, only one
    Well i guess most of the users here don't use RGBW strips then.
    @Fibaro
    Could this be a future feature?
    We really like the color wheel but we also like to adjust the values for the RGBW stripes so we get a perfect color-wheel.
    Using different strips always get different color results so this wold be a great feature.
    speedy, I passed you suggestion to our team. However it is a matter of changing RGBW device, so it will take a good while to decide about this and implement your solution.
    Ok, so it not possible via firmware/software.
    Hopefully we will se this feature in the future.
    Thank you for your answer!
