I use a RGBW micro-module with a LED strip.
It works properly but I have a problem with user program.
I can add program but when I click on it, it doesn't work.
In the user interface the program is tagged with a '>' and the ON OFF button goes ON, but led doesn't light.
Here are the list of my programs (
When I select "Fireplace" (id:1) in the HC2 interface parameter 72 goes to 6 and it works:
When I select "test1" (id:16) it goes to 1 but it doesn't work:
My goal is to use a LUA script, but once again, it doesn't work:
I tried to remove and discover again the module, not better.
Note that the personal programs are still alive after a remove / discover, that mean personnal programs are not linked to the module but are globals.
I guess the problem is that my personnal program ID is 16.
Is there any way to reset the program list in the database to restart to 6 (1 to 5 are dedicated to factory programs) ?
