I have 3 FGD211 Dimmers. When I put a dimmer on a certain level of power the other lights on the other dimmers starts blinking and flashing. It doesn't matter which ones. If I have two on low the third might flash as well. It seems that it needs to be at an exact procentage or something.
Any one?
Guest GG
Can you draw a sketch of your setup, how the lights are connected to the dimmers?
What type of lights are you using?
    I had an electrician do it so I actually don't know how it's wired. But I'd guess it's OK.
    The lights are 12V spotlights inside the ceiling (four different ceiling-sections). I can't find the transformator since it's hidden inside the ceiling somewhere...
    Just thought if someone had an idea? It's pretty strange how they can affect each other.
    BTW, 3 of the dimmers are mounted in the same outlet, just next to each others. But the last one is mounted in a whole different room, and that room can also start to flicker at certain procentage.
    Replace dimmer to 2x1.5 Fibaro Relay switch, LED and 12V transformator not be work, and flashing.
    Have you tried bypasses?
    Without knowledge about connection we can just make guesses. First thing to try is adding bypass. Second, you can try mounting ordinary bulbs and checking if they work properly. If so, you should try to adjust parameter 20 differently and/or disabling parameter 10.
    Nope. Do you think that would work?
    It's not LED-lights though.
