Gong mad with Door Sensor battery replacement
Guest paogig
Sorry forum, I remember several topics on This, but not able to find them anymore!!!
I tried to replace batteries but no joy... How to do it?
If you have no problem with it then just replace it. If you want to follow the manual in order to avoid arlams the manual states this:
"BATTERY USE:
The Fibaro Door/Window Sensor's battery life is up
to 2 years, on default settings.
Current battery level is displayed in the Home
Center 2 configuration interface. If a battery icon
turns red, it means the battery needs replacement.
In order not to trigger an alarm when replacing the
battery, II-nd association group must be deleted
and the Sensor's configuration must be changed to
default, prior to the battery change."
Guest paogig
    Thanks ursv, I have replaced it but level was low!
    Now i have excluded the device but I am not able to include it again
    my tips:
    try exclude before including first.
    Could take quite a few attempts specially if sensor is farther away from hc2. (no routing through mesh)
    I had to drag hc2 with a long electric extention through the house to get it inc/excluded.
    If that doesnt work try and use the reset procedure as stated in manual and forum.
    Good luck!
    Dont give up
