Alarm 0-10v output
Guest imparator
Guest imparator
Hi, i have a galaxy gd 96 alarm system
that have 8 relais outputs, the output is only 0-10v
i want to use this ,
to look is alarm on, nobody at home, then put some adapters to off
i can give the ports 1-2-3 or 4. the possibility to activate only
if alarm is on or off
alarm is partly on ( first floor is secured, second floor is free zone to walk en sleep ) put only downstairs off )
can i use for analoge 0-10v outputs fibaro doorsensor , or universal sensor , or rgbw sensor ?
which one is the best to use it ?
I assume these outputs are binary ones? Just 0V or 10V? If that is the case, you have 2 options: to use RGBW, remember about connecting ground potentials of these 2 circuits. The 2nd one is to connect external relays with coils enabled by alarm outputs, detecting short circuit with UBS or D/W.
Guest imparator
  • My rgb module is on his way,
    can i see the state of the inputs by analog input 0-10v ?
    i checked my alarm,
    on = 12v ( is this a problem ?)
    0ff = 0v
    so when i connect the rgb module to input 1 , can i see the state of the input 1?[/i]
    Yes, you can see the value on analogue input. Maximum rating is 10V, so any issue that may be effect of too high input voltage may void the warranty.
