Best option to configure as "controlled device" fo
Hi All
I have 14 fibaro' relay controlling my underfloor heating system (1 per each room) and I'm using the heating panel. All it is working fine, but I'd like to know If are there any option that I could use to have all of these devices in one group. I mean, If I'm configure the "controlled device" (at fibre relay advance configuration panel) parameter as ...? ... (i do not know what) can I control all the relay on/off with one touch? Thanks in advanced
Gustavo
I do not have the answer to your specific question. But you could create a scene to turn them all on, and a different scene to turn them all off...
    Thanks for your response. Of course, that i could create a scene. But I'm thinking, as an example, that if you configure all as lighting, then I have the option from my smartphone, to turn them on/off by pushing on the lamp icon and so on... That's is my question, in order to find the best configuration.
