How to create a scene that only works at night
Guest Eduardo
Hello there.
I have a universal sensor with a regular motion sensor at my garage. And I would like to create a scene to turn the lights on my garage only at night when have movement and after 120s without movement the lights turn off. I was trying to do this with the sunset clock on fibaro, but not managed to get it working....
Can anyone help.
Regards
Eduardo
7 answers to this question
Hello there.
Can anyone help.
Regards
Eduardo
Eduardo,
1) Create a variable called 'Night' or whatever name that suits you.
2) Create a scene that sets the variable to "1" at sunset and a second scene resetting it to "0" at sunrise. Don"t forget to switch on the "Start with HC2"-option on the general tabpage.
3) Now create your scene for your garagelights and make sure that you have as one of your conditions that the variable "Night" = "1" AND the motionsensor is activated and then the lights are switched on.
I think you could use this code:
Guest Eduardo
    Tks Ace02!!
    Thats almost what i need.
    But I need something that uses the sunset and sunrise time from fibaro, because here in Brasil we have daylight saving time and in the summer the lights turn on when still bright. And I don´t have a Lux sensor just movement....
    AS far as i know the code has both.. I am using this with sunrise and sunset.. And if You read the comments in the code, it tells how to "disable" the Lux sensor..
    Think it would work the way You want..
    Guest Eduardo
    Sorry I´m very newbie in Lua, but do you think it will work with the universal sensor attached to a regular movement sensor??
    Guest David R
    Hi Frank how is this done. I have had Fibaro a week and Im still trying to learn it
    Guest Eduardo
    Hello Frank.
    I´ve tried this but no luck either. Now I chagend the universal sensor for a 4in1 aeon labs, and put the scene with the lux level...and now its working
    [ Added: 2014-10-25, 15:30 ]
    This is the scene that I tried, but doesn´t work.
    %% autostart
    %% properties
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    if (
    ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and os.date("%H:%M", os.time()+20*60) == fibaro:getValue(1, "sunsetHour")) )
    then
    fibaro:setGlobal("night", "1");
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
    if (
    then
