Guest David R
Hello I am completely new to Fibaro and LUA and was wondering how to do an all off switch at the front door. At the minute I have it as a relay s2 activating a scene if its either switched on or off with a momentary switch. I made the scene using blocks as I am still just started out learning LUA but here it is in LUA.
%% properties
76 value
%% globals
if (
( tonumber(fibaro:getValue(76, "value")) > 0 ) --if turned on--
or
( tonumber(fibaro:getValue(76, "value")) == 0 ) --or if turned off--
or
then
setTimeout(function()
fibaro:call(62, "turnOff");
end, 2000)
fibaro:call(60, "turnOff");
end, 4000)
fibaro:call(49, "turnOff");
fibaro:call(70, "turnOff");
end, 6000)
fibaro:call(58, "turnOff");
end, 8000)
fibaro:call(56, "turnOff");
fibaro:call(64, "turnOff");
fibaro:call(66, "turnOff");
end, 10000)
fibaro:call(51, "turnOff");
end, 12000)
fibaro:call(14, "turnOff");
end, 14000)
fibaro:call(9, "turnOff");
fibaro:call(11, "turnOff");
fibaro:call(16, "turnOff");
end, 16000)
fibaro:call(6, "turnOff");
fibaro:call(19, "turnOff");
fibaro:call(36, "turnOff");
fibaro:call(40, "turnOff");
end, 18000)
fibaro:call(44, "turnOff");
end, 24000)
Is there a better way to do this so I don't have to have on or off? Just activate scene. Remember im completely new so go easy and everybody has to learn somewhere
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Thanks
6 answers to this question
