"Simple" code not working in 4.017 / 4.018
This is code from a button in a virtual device. But, it does not toggle the variable. And i get no error output.
Am i missing something stupid?
[/code]
5 answers to this question
    So, are variables always strings now? Does that also mean if tonumber(getstatus) == "0" ?
    [ Added: 2014-10-16, 19:32 ]
    No, that code does not toggle the variable either.
    I just tried that and it seems to be working. Could you please add some fibaro:debug() after the variable is being set and post results here?
    Sure.
    Will do after work.
    I'm having problems with debug and tonumber after update to 4.018.
    Try this.
    a = "3"
    fibaro:debug(tonumber(a)) -- shows nothing
    fibaro:debug("a = "..a) -- now it's visible
    aa = tonumber(a)
    fibaro:debug(aa) -- shows nothing
    fibaro:debug(""..aa) -- now visible
    Is this a syntax isssue??
    I noticed that you can only put ALPHA variables in global variables AND from the variables panel you can only enter NUMERIC variables, eg 1 , 2.5 etc. ?!!
    So tonumber(x) into setGlobal does not work!!!
