I am using Homee is my gateway for my Fibaro products.
Everything fine so far, but now I want to change the parameter no.6 of my motion sensor.
Current setting at this moment should be 30 seconds and it want to change it to 45 seconds.
In the manual I cannot find the correct value to set.
Any help is welcome
[ Added: 2014-10-23, 18:04 ]
Maybe it is clear what I am looking for because this change is something you guys should be able to do anytime!?
In my gateway I cannot check the actual values of the parameters.
In the moment my parameter 6 was not changed and because of this it is 30 seconds of time.
I want to change it to 45 seconds.
So my question is: can I put in durectly "45" or do I have to calculate something else?
[ Added: 2014-10-24, 06:40 ]
Solved ! I got help in a different forum.
I can directly put in the value (time) I want.
Topic can be closed.
