My smoke detector gives the last few weeks spontaneous beep / alarm sounds. It takes a few seconds and then stops.
HC2 with 3590,
Smoke has new battery, removed and added new with everything as default.
Smokedetector situated in the hall on the ground floor
Other smoke detector on 1st floor gives with same defaults no problem (escape Flight route principle)
Because i went back to default with the smoke detector and tried everything like to know what this is and if there is a soloution.
I would also like to know what the impact is when the sensitivity is adjusted to 3 instead of 2.
Because setting a delay on smokedetectors without knowing why, and what you doing for is dangorous.
