i am currently installing the Temperature Sensors and i have some strange behaviours with the temperature logs.
First of all, i was using the default configuration:
60. TEMPERATURE REPORT THRESHOLD : 1 Degree
62. INTERVAL OF TEMPERATURE MEASURING: 900s
64. TEMPERATURE REPORTS INTERVAL: 0s
Now what is exactly going on here? My Temp gets measured every 900s, but is never send contantly to my controller because of Interval 0s ? It only sends when Temp is differing for 1 degree ...? This means, i can only see the new value in my android app when the new value is 1 degree ?
So i thought i play around with the settings:
60. TEMPERATURE REPORT THRESHOLD : 2 Degree
62. INTERVAL OF TEMPERATURE MEASURING: 500s
64. TEMPERATURE REPORTS INTERVAL: 500s
Now what is going on here? I am not sure, but i think it is like this:
The Temp measurement is every 500s, and the value is also contantly reported to my controller after 500s. AND i get a report when its 2 degree difference...?
So i am getting two reports when the measurement is done after 500s and 2 degree difference...?
Also i am checking the events log on my Tablet, and i thought it should show a log every 500s ... But this is not the case. Sometimes it is, but not always....
Also The Event shows for example: 23Degree>23Degree.
Actually this event is useless.
I was hoping the measurement is send after 500s, so that i can see the new value on my tablet/smartphone, BUT the event is only shown for 2 Degree difference, which would make sense for me.
Now my event log is foll of useless informations ( 23Degree>23Degree ... who cares?).
Can i set the reports to be send every 500s (for example), but the event log only shows new events on the parameter 60?
Greetings
