I would like to do the following in my hall to switch the lights on and off:
When i am opening a door the light will go on in the hall. When i close the door the light will go off in XX minutes. If the door stays open, the light will be constantly on. Each door that give acces to the hall has to do exactly the same. All the doors are equiped with the Fibaro doorsensors.
It sounds simple but with the lua blocks i can't get it working. Can i do this simple cirquit with lua and how?
create variable door, give it value 0
block scene 1:
if door 1 = open
or
door 2 = open
or
door 3 = open
then varibele door = 1
block scene 2
if door 1 = close
or
door 2 - close
or
door 3 = close
then varible door = 0
block scene 3
if door variable = 1
then turn light on
block scene 4
if door variable = 0
then turn light off in xx seconds
i
    Hello akatar,
    Thanks for the reply. Unfortunately your scene does not work. If I enter the hall through a door (for example door A) the door will go open and close. when i open the second door and leave it open for some time the previous timer of door A will set the lights off.
    hi hugohekk
    How about
    block scene 1:
    if door 1 = open
    or
    door 2 = open
    or
    door 3 = open
    then variable door = 1
    block scene 2
    if door 1 = close
    and
    door 2 - close
    and
    door 3 = close
    then variable door = 0
    block scene 3
    then turn light on
    block scene 4
    hope that helps
    Brian
    Another way to do it? (not tested)
    block scene 1:
    if door 1 = open
    or
    door 2 = open
    or
    door 3 = open
    then variable door += 1
    block scene 2
    if door 1 = close
    or
    door 2 = close
    or
    door 3 = close
    then variable door -= 0
    block scene 3
    if door variable > 0
    then turn light on
    block scene 4
    if door variable <= 0
    Although achieving your goal, you may consider the use of a PIR sensor?
    Hi hugohekk (and others),
    If you want to do this with Lua rather than blocks, you can use the following scene:
    It gets triggered by any door. Once triggered it stays running until all doors are closed for the amount of time specified by delay. If any door opens again during this time, the scene notices this and resets the delay. The doors are checked every second once the scene is triggered.
    An optimisation you could work on: don't start the loop until all doors are closed.
    Happy automating,
    Adam Bewsher
    WOW Adam, this works great. Thanks a lot man, this makes me happy
    Hi hugohekk,
    I am very glad that I have made you happy! May the happiness continue!!
    Happy automating!
    Adam Bewsher
    • 3 months later...
    Hello, i don't know why but the following scene stoped working with the update to 4.033. Do you guys know what went wrong?
    doorID in pairs(doorIDs)
    Can you explain what this does?
