TKB HOME TSM02
Hello
Do you test TKB Home TSM02 and TZ04 compatibility, because i have reply from TKB Home where they say that Fibaro do not support their devices with 400 series chip.
kmeta, devices with chip from series 4 can have difficulties in integration, since even Z-wave withdrew from this generation due to its imperfections.
My TKB Slim Multi-Sensor TSM02 worked fine in 4.057 but after updating to 4.058 is stopped reporting on movement and LUX. I tried soft configure and all sensors Magnet, Temp and LUX disappeared leaving only movement. The other missing modules do not appear in the hidden devices either. I see what has been written above but this sensor worked before and now it does not. So has support for it been removed or was this a mistake/bug?
Fibaro, It would be nice to know when you will create a template for TKB TZ88E.
