I Had wrote a code for just turning on my led spots for 3second and then turn off ,
my device has ID 16 , and after i press run on the fibaro scene and it didn't turn on the spots , i want to know what's wrong in this code :-
%% properties
%% globals
local myvariable
fibaro:debug('start the program')
myvariable = fibaro:getValue(16, 'value')
fibaro:debug('my variable='.. myvariable)
fibaro:debug('now i will turn on LED spots ')
fibaro:call(16,'turnon' )
fibaro:sleep(3000)
fibaro:debug('now i will turnoff LED spots ')
fibaro:call(16, 'turnoff')
[/b]
Hey,
Really simple - you need to use 'turnOn' and 'turnOff', not 'turnon' and 'turnoff'.
It's case sensitive.
Other than that, seems fine.
Hope it helps!
Dan
    Hey,
    Hope it helps!
    Dan
