Validation logic "NOT equal" in block scene editor
is there any possibility to check a variable value to NOT EQUAL in block scene editor?
I've created a variable (e.g) "light automatic" with predefined values (active, inactive and locked) and I wan't to check this variable in a scene for the following conditions: light_auto=active and light_auto<>locked (!=)...
(But I can only check "equal, greater or less" !?!)
If not available in the actual stable release, is it maybe planned in future releases?
HCL 3.593
Best regards
Tan
4 answers to this question
you can try ~= for your lua code. block scene does not have not equals i suppose.
opps you are using HCL
Tan, from 4.x we gonna add that option
    @MalvinYNJ: Yeah, the missing lua code is really annoying and the HLC with only block scene editor is (in that version) nearly useless
    /emoticons/default_icon_sad.gif" alt=":-(" />((((
    @A.Socha: Thank's for the answer, that would be really GREAT !!
    /emoticons/default_icon_smile.gif" alt=":-)" /> Unfortunately for now, there are some missing features like time based conditions and the possibility to move/insert blocks at/to specific positions, that makes the block editor very very hard to use...
    Is there any list with planned features/changes for the upcoming release? (and maybe a 4.x beta program also for HCL users? Till now, it seems to me, that everything is concentrating to HC2...
    • ~= not equal to
