Can i charge ''Panasonic Lithium CR123A'' batteries?
If not, what kind of batteries can you suggest for replacement?
Thanks for the answers
No, you cannot charge the bundled battery. There are rechargeable CR123 batteries.
Replace it with a new CR123A. It's a standard type albeit known by many names:
gediminasv705, you should never recharge batteries that are not clearly marked as such. It may result in an explosion or damage of charging device.
