phoebe 0
I have several RGBW modules and try to control them in parallel with one dual-paddle battery operated switch.
The problem is that while dimming different light intensity is set-up on modules. I know that the commands sent to modules are Start/Stop dimming. I suppose, due to some little difference in internal speed/sync of modules, different level is set up in modules. I tried to play with params 8/9/10/11 but with no luck.
Have anyone had the same problem and solution?
6 answers to this question
