how to disarm devices by scene triggered by physical device?
Goal: to enable or disable alarm
Trigger: RFID tag
Setup: see scenes below
Question: arming works (scene 8, 9), but why does disarming (scene 28, 29) not work? do I have to do something with alarm pincode?
LUA CODE BEHIND RFID TRIGGER
%% properties
88 value
--%% globals
--Alarm_DeurRaam
if
tonumber(fibaro:getValue(88, "value")) > 0
then
if fibaro:getGlobalValue("Alarm_DeurRaam") == "UIT"
then
fibaro:setGlobal("Alarm_DeurRaam", "AAN");
--fibaro:debug("AAN");
--fibaro:call(76,'sendpush',"Door/Window Arming Started");
fibaro:call(76, "sendDefinedPushNotification", "17");
fibaro:sleep(30*1000);
fibaro:startScene(8); --Raam
fibaro:startScene(9); --Deur
fibaro:call(62, "turnOn");
--fibaro:call(76,'sendpush',"Door/Window Armed");
fibaro:call(76, "sendDefinedPushNotification", "16");
else
fibaro:setGlobal("Alarm_DeurRaam", "UIT");
--fibaro:debug("UIT");
fibaro:startScene(28); --Raam
fibaro:startScene(29); --Deur
fibaro:call(62, "turnOff")
--fibaro:call(76,'sendpush',"Door/Window Disarmed");
fibaro:call(76, "sendDefinedPushNotification", "18");
SCENE 28 AND 29 CREATED by GRAPHICAL BLOCKS
see attachment with printscreens
make sure you add the pincode when disarming stuff:)
i use scene and vd where id22 is the vd
scene:
%% autostart
%% properties
22 value
%% globals
if ( tonumber(fibaro:getValue(22, "value")) > 0 )
then
fibaro:call(80, "pressButton", "3");
button for vd to disarm where xxxx is your personal pincode
fibaro:call(70, "setArmed", 0, xxxx);
fibaro:call(67, "setArmed", 0, xxxx);
fibaro:call(52, "setArmed", 0, xxxx);
--fibaro:call(79, "setArmed", 0, xxxx);
fibaro:debug("Disarmed");
fibaro:call(2, "sendDefinedEmailNotification", "2");
fibaro:call(60, "sendDefinedPushNotification", "2");
    how easy can it be...!? thanks, this works!
