Temp sensors from Universal Sensor Shows 0°C after 4 Month
Dear All,
As explained in the title, I have issues with 2 DS18B20 connected to Universal sensor.
They displayed accurate temp for 4 month and since yesterday both show 0°C.
Universal sensor is perfectly supplied with 12VDC and communicates perfectly with HC2 when you try to reconfigure the device.
But even after reconfiguration, it doesn't give the real temp back...
Any idea somebody?
Hi
The same thing happened to one of my sensors. I fixed by excluding it then including it again. Then I had to change the scenes because the ID was different .
hope that helps
Brian
    Hi Brian,
    The problem is that this multisensor is underground below a jacuzzi and that both temp are inside the heating system. Even if it communicate, I can't exlude include without taking all the stuff out (I tried and it doesn't react with remove) which means about 3 hrs under 40 degrees (Congo
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ).
    You know, I'm tired of spoiling so many hours of ex/include device in order to fix fibaro issues ...
    [ Added: 2014-11-07, 08:07 ]
    Yesterday evening, both temp came back to life. I did nothing...
    I'm not comforted as I know now that they can quit again while they're the basement of a heating system.
    Tibus31, can I ask you hat temperatures sensors are exposed to?
    Hi J.nowacki,
    Around 40°C max.
    Tibus31, this looks strange, if this happens again, please contact support team.
