I have buyed some new fibaro eye motion sensors, one of them which is round about 2 meters from hc2 has now battery level in red. That means this motion sensor has 2 months ago a new battery and this is now empty.
Is this a known bug in Beta's or what have i done wrong? Should the battery not at least run a year in those sensors?
2 months? This sensor is in the living room, is this a problem?
yuzo, if sensor is being breached all the time and setting of blind time is low it is possible. Also reports frequency is important parameter - frequent reports will drain battery enormously.
I have the same problem. Flood sensor is empty according to HC2 beta 4 while I just replaced the battery. Same problem with smoke sensor.
Smoke sensor is also not showed in interface but still receive a message about an empry betere. So no, no user issue but a HC2 4 beta issue as I have had te smoke and flood sensor running fine (thats to say no message about empty battery) in 3.59.
Also door sensor is dead node. So I say beta 4 is having problems with battery devices.
I've got all my battery operated devices dead after the upgrade to 4.018. I replaced the batteries and still don't have connectivity... I don't know what to do!
    Hell Nowacki,
    i have 5 more sensors on HC2 attached, all devices are configured same and the others are not having problems with battery.
    This sensor is near two blinds and near to hc2, 2meters round about to hc2 and also to blinds. Is it possible that this is a routing problem ... or something related to that?
    [ Added: 2014-11-07, 17:54 ]
    Strange, today all my battery driven devices are dead. Also wakeup is not possible?
    After resetting the hc2 all devices were dead again, but wakeup was possible and now the sensor with empty battery has a full battery again !
    yuzo, jnevestdl,
    GO back to stable 3.590 and You will forget about problem with battery operated devices. 4.x is beta software and has big problems with battery operated devices.
    yuzo, jnevestdl,
    thanks for your tip, but the beta is ok ... its a beta and thus it has bugs. We're trying to help developement.
    Brgds,
