Problem with double relay switch FGS-221 v2.1-v2.3
I bought 10 devices. Of these I have problem with 2. Same problem. Try to set parameter 14 to 0 (1 byte dec). Device don't accept it. Get "Failed at - setting user configuration" Strange, because the other 8 works. I use momentary switches. What to do? I can set the relays without any problem but of course I have problem to turn on the light if I dont stay near the switch and press it whole the time...
What to do?
Is this error on hc2 or hcl?
    Its Vera 3 controller
    pln8421, please unplug the Relay Switch, hold down B button, plug it in, wait for relay to click, release button and unplug and plug it again. This will reset the device. Include device and try again. You should also contact manufacturer of you controller to make sure it is not its fault. Of course if you suspect defect of module you are entitled to warranty procedure.
    First go to settings of that particular device by click the wrench icon go to
    Device options>> Update neighboring nodes.
    Or you can try going to advanced zwave settings and trying "Heal Network".
    • 5 years later...
    @j.nowacki
    I've done that several time its not working .. i cannot hear the relay click ... after i hold down B button and plug in the relay again
    The relays FGS221 v2.1 ARe new ... could ypu please help me finding a solution?
    Thnaks
