Guest solarium
Hello all,
I'm a new customer of the HC-lite.
I'm a little disappointed, because of the limitations of the HC Lite software.
I was thinking that the LUA code was not mandatory to be able to use and play with my Zwave devices, or others connected objects (netatmo, withings, etc)
But once associated with :
- a fibaro Wall plug
- a fibaro smoke
- a fibaro motion sensor
- a fibaro door sensor
I feel ... sad ... about the possibilities.
- No debug availlable for scene or virtual devices.
- Only single HTTP request possible for virtual devices
=> Need to deport scripts to another server ... to make an authentication ...
- No way to create custom graphs of anything. (only the power of my single wall plug ...)
- Did not found the Smoke Graph (like
)- lots of difficulties to configure IP camera with a password (had to remove the password)
but no way to record a screen ? (there is a button, that do nothing)
I see that the HC2 users can play with a V4 beta... When HCL will be able to play also ?
HCL without plugin is just ... like a waste of money for me.
Thank you for your responses.
17 answers to this question
