Scene not running
Hey all,
I'm still having fun.
Have a scene which works fine with I click 'Run'. But it doesn't work if just left alone i.e. to 'run' on it's own.
Triggers seem fine; Lua code is very simple.
I was thinking maybe it's something to do with the polling of scenes?; how is that defined?
%% autostart
%% properties
11 power
%% globals
local power = tonumber(fibaro:getValue(11, "power"));
fibaro:debug ("power:"..power);
if ( power > 1.0 ) then
-- fibaro:call(6, "sendDefinedEmailNotification", "1");
fibaro:debug ("Email sent"..power);
fibaro:call(6, "sendDefinedEmailNotification" ,"fghfhfg" ,"pump" ); -- doesn't work
fibaro:call(35 , "sendPush" ,"power"); -- does work but only on 'run'
Been around 10 minutes now and nothing; so assume scene isn't running???
thanks
I am no LUA expert but this works for me..
So it has the loop command and sleep for 60*1000
I use this scene to switch lights on in my house when I have the global variable Holiday set to On.
%% autostart
%% properties
%% globals
HolidayLight
HolidayMode
DayTime
local num = fibaro:countScenes();
if (num == 1) then
-- fibaro:debug('1 scene is currently running');
else
fibaro:debug('Number of the scenes running: ' .. tonumber(num) .. ". Aborting current scene");
if (fibaro:countScenes()>1) then fibaro:abort() end
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
while true do
if (
( fibaro:getGlobalValue("HolidayLight") == "Off" )
and
( fibaro:getGlobalValue("HolidayMode") == "On" )
and
( fibaro:getGlobalValue("DayTime") == "Off" )
and
( ( currentDate.wday == 1 or
currentDate.wday == 2 or
currentDate.wday == 3 or
currentDate.wday == 4 or
currentDate.wday == 5 or
currentDate.wday == 6 or
currentDate.wday == 7) and
tonumber(os.date("%H%M")) ==
tonumber(string.format("%02d%02d", "19","00")))
then
fibaro:call(108, "turnOn");
fibaro:call(109, "turnOn");
fibaro:setGlobal("HolidayLight", "On");
fibaro:call(2, "sendEmail", "Office Lights On", "Holiday Lights are now On");
fibaro:sleep(60*1000);
    Thanks!; but I'm confused.
    Are you saying my scene only run's once not continually?
    I want it (for example) to execute every minute - how do I do that??
    thanks again
    [ Added: 2014-11-11, 16:44 ]
    Ahhhhhhhh!!!
    You have a do while true loop!
    On verde you set the interval!!! ; it now works! - THANK-YOU!
    Still can't get email notification going though; but the push works
