Anyone has any idea do Fibaro Dimmer Module go into hibernation mode if untouched for a minute or two?
Just encountered this issue. Had to double click to "wake" the dimmer module up before it can be use again.
Admin, please advice.
Thanks.
I have 5 Dimmers and 1 of those has the same problem.. sometimes...?!?!
I have had this problem when using Associations on ID2.
Changed this to SceneActivation and the problem was solved.
MalvinYNJ, please change parameter 10 to 0, see if that helps.
i have the same kind of problem with dimmer. I use three clicks: one - no change. second - no change, and then third - and finally lamp is on.
It's on 4 of 15+ of my dimmers, and clearly related to S2 association.
All 4 my problem dimmers have S2 group association.
All other conditions are quite different between them: type of lamps, 2 or 3-wire connection, have bypass on load or not.
To some "helped" to set parameter 9 to 0.01 instead of 0.05.
But one dimmer is still with problem. Trying to set parameter 10.
Alex57, changing S2 associations to scene activation or adjusting parameter 10 should do the trick
Changing parameter 10 disables smooth on/off and looks really nasty.
Fibaro, why can't you just fix this in the module firmware?
eg1l, this issue was passed to hardware team, I just suggested a fix that works for now.
after some days, i can confirm - set parameter 10 to 0 resolves this problem.
But this is kind of bug, and 1.9 and 2.2 version dimmers both have it
