Is it possible to turn off the temperature measurement in the flood sensor?
One of my Smoke Sensor producing a chime every ten minutes. What does this mean or have I done a mistake?
Smoke sensor has weak z-wave strength. You can switch parameter 80 to 0 and this should eliminate this signal.
Why dou you need to turn of temperpature sensor in flood sensor?
I think you can hide this from the picture.
Lauri
    thank you, I changed the parameter.
    I want to turn it off to safe Battery because the Smoke sensors already give me the actual temperature.
    thanks
    MuM-Home, in such case just increase interval and tresholds of all temperature reports.
    thanks for your help... it works
