When you enable cameras, HC2 and other stuff to be seen via internet, be careful. It should be obvious to change default passwords, but seems not.
Also when you change the password, there is always possibility to hack passwd or use several bugs that are out there to gain access to your devices.
I would never portforward devices straight to internet.
The less you expose to the internet, the safer you are.
