Open/Close Gate with Universal Sensor
Hi all,
I am quite new to Fibaro, and I would like to do the following to start:
I own a Gate-opening System of "Nice", which has the possiblilty to trigger the door open, -stop, and -close with a potential free contact.
My idea was to attach the Universal Sensor to the "Nice" Control-Units 24V current, and use the binary output for the Gate-open trigger. Activating the trigger a second time would stop the gate, anothertime would close the gate.
Is my assumtion correct, would this work that way?
Thank you very much!
cheers
joystick
5 answers to this question
I also have a nice gate opener.
First I connected 2 Rollershutters 2 to the Nice-interfaces outputs. That worked with my HC2 and the original remotes.
But finally I just ripped the Nice-electronics out and now I open and close the gates with 2 x Roller Shutter 2.
But the motors have to work on 220 AC!
The outputs of the Universal Binary Sensor cannot be controlled, they are tied to the inputs.
True! The UBS is nothing more or less than a sensor, it can't be controlled by the user.
HI
I am using a 2x1.5w Fibaro relay with my Came electric gates and these work a treat. You just wire one switch into a "open" command on the gates and another switch into the "close" command on the gates.
Must be 240v
very sad
