enable / disable a scene
is there a simple methode to enable / disable a scene from another scene?
6 answers to this question
Enable: fibaro:setSceneEnabled(id, true)
Disable: fibaro:setSceneEnabled(id, false)
    thank you.
    Hello sir, i am a noob. But where do I put in this script?
    In a lua script or a VD button
    LUA scenes not. But you can create a Virtual Device, add a button with the code you need.
    after that you can use this VD to enable/disble a scene, but you can also create a block scene that press the button in the VD
