diderik 6
Ok, so I have set up scenes to turn on the lights when movement is detected, and then off 15 minutes after last detected movement. This works fine, but in the bathroom I have RGBW controllers and LED strips that I sometimes like to dim. The problem is that, when dimmed, the next time movement is detected, they turn on at full blast again.
I have tried linking movement to a scene that first checks whether the lights are OFF, and only then turn them on, but of course, this cannot be an active scene, or the lights will never be off. I have noticed similiar instances; when manually starting a scene with conditions; the THEN actions are performed regardless of whether the conditions are met or not. I may have missed something obvious here, though.
How can I get around this problem? In short; I want to keep having the lights turn on at detected motion, but if I dim the lights I want them to stay dimmed.
And; I am on the Home Center Lite, so no LUA. (I migrated from HomeSeer, and when choosing between HC2 and HCL, I could not see any reason why I should need LUA, but the block scene capabilities of the HomeCenter are nowhere near that of HomeSeer, so no I keep pushing jobs to my pi running domoticz via virtual devices.)
6 answers to this question
