Question with LUA scenes
Guest David R
Guest David R
Hello im new to LUA and im trying to program a scene that notifys me when somebody comes in my house on a Thursday morning. So I have written this. Only problem is it doesn't work. Can anybody tell me where im going wrong. Thanks in advance
%% properties
199 Value --front door sensor
%% globals
if (fibaro:countScenes() > 1) then
fibaro:abort()
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
( ((currentDate.wday == 5) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) > "08:00") )
and --on thursday and if the time is greater than 8am
( ((currentDate.wday == 5) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) < "13:00") )
and --on thursday and if the time is less than 1pm
( tonumber(fibaro:getValue(199, "value")) > 0 ) --if front door is open--
or
( tonumber(fibaro:getValue(199, "value")) == 0 ) --if front door is closed--
then
fibaro:call(125, "sendDefinedPushNotification", "80"); --push to my phone--
setTimeout(tempFunc, 60*1000)
Please, use Code tags to post listings and format your code so we can read it easily.
You declared function that contains all code, but you do not call it anywhere, so code triggers and ends without any results.
