In my house I have floor heating.
Since the systeem was not working well I have replaced all the controls with a Fibaro FGS221 switch.
Output one Controle Valve
Output two control central heating pump
Fibaro Uni sensor for the room temperature measurement.
Temperature sensor and the Valve controle are linked for heating controle.
Heating Pump is not linked since this one need to run a bit longer and I need to start the pump from time to time for water circulation
Heating scheduling will do the rest.
When the Valve is open Pump time will be set to 15 minutes
When the Valve is closed the pump will stop after 15 minutes.
Water circulation is a simple scene that will start every few days and run for 10 minutes.
All is working fine.
Script need to be optimized a bit more..suggestions are welcome.
Update 18/11
Done a bit more optimise
