-- Could i install dimmer with( two gange switch) to control (two gange loads) or i should install one dimmer for each gange for example a chandelier?
-- onther related issue is could i install relay switch with two way switches (i mean the same load controlled from two places )
/emoticons/default_icon_exclaim.gif" alt=":!:" />
Yes you can install the
Dimmer Module with 2-Gang switch or Momentary Switch type but make sure the Loads not exceed 500W.
Relay Module is it Single or Double , but for two way switch you can do that..
Hope that helps.
Best Regards,
Krisshna
    In the dimmer question , i ask about if the dimmer could works to control 2 different and independent loads as same as 2X1.5 kw relay switch ?
    Guest spazpeker
    I have the relay controlled with 3 switches 2x 2 way and 1 x intermediate
    The dimmer can control one load only. The second buttom can be used to control a different device or for scene activation though.
    noor, UrSv is right, only single load can be controlled directly and 2nd button can be used to control scenes and associations.
    thank you for responding . I get the point..
