I want to create an alarm system with the help of fibaro modules but therefor I need the help of the community.
I have alarm contacts integrate in my windows. The wires are located in a 10x10 box. This box also includes electricity. Is there any sensor which I can use to get a signal if the window is open or not. And I am able to use this in the alarm mode of the Home Center?
I also need a siren for outside use. As there are only Zwavesirens for inside I want to ask if it is possible to buy a normal outside siren and trigger it with a fibaro module?
Thank you very much for your helps.....
MuM-Home, Do you have any relay outputs to which you can connect UBS's to? Is so, you can add them and arm/disarm as they were D/W sensors.
External siren can be used, eg. Satel offers such devices. Just enable it by connecting to power supply with Relay Switch
    ok thank you, I will try it
