Dual relay switch
hi all,
I'm new to this, so perhaps I'm doing something wrong.
I've associated a Philio PAN04 dual relais switch with my HC2. It showed up as a master with with two slave switches. I can switch on/off the master and both relais go on/off. If I switch of one or the other of the individual slave switches, nothing happens.
what's wrong here??
thanks!
emiel
8 answers to this question
Fibaro doesn't (want to) support this properly. I have some of those as well.
It can't be that hard for Fibaro to support it.
I wonder if it will work in V4 which will be released "soon" in 2017 or so...
    Meanwhile I've made some progress.
    You can use parameter 3 to either select Relay1 or Relay 2, too bad you can do that only in the main switch.
    But if you use lua scripting, you should be able to program the main switch before you switch it. It's just that Philio has a terrible manual, or it's my lack off lua scripting.
    So if anyone knows how to program the Philio dual relay switch with the proper paramaters.....?
    Than we solved another issue
    cheers
    emiel
    Does anyone know if it is working or do we have h fix for this?
    Please let me know as I have one of these working with a Vera Edge perfectly but would not mind transferring it to the HC2 but refuse to go climbing in ceiling space for nothing!
    Mybee in 4.031?
    I run 4.031 but refuse to guinea pig anything else as at the moment i have the ability to switch lights on and off which is a huge step up from previous releases
    okej, it´s working in ver 4.031 I just upgraded. However you need to reinstall the device (add / remove)
    same here! working like a charme!
    cheers
    emiel
