why deso fibaro:call(45, "pressButton", "2&q
in the same virtual device, id is 45, there are to buttons in it.
first button lua call 2nd button, fibaro:call(45, "pressButton", "2");
not work, so
2nd button full id is="Button2", the third parameter i change to 2, "2", "Button2" all not work?
or pressButton only use between two different devices?
[ Added: 2014-11-21, 09:49 ]
i got it, it can work with two Independent button, but if two button is one control button in one line, it does not work, how to do ?
To get ID of certain button, go to HC2_IP/api/devices?id=XX where XX stands for id of your virtual device. Now look for your button in JSON. Install JSON Viewer plugin to format it to readable form.
