New LUA Beginners
hi all
I am new to fibaro and want to learn more about LUA
but first how can i use LUA to see the picture get from internet like below picture
Could anyone teach me step by step ?
5 answers to this question
Hi chinastar89, glad to have you in our community! I am afraid I do not rally understand you try to achieve. If you are new to LUA you should start with something simple, like controlling modules.
Hi!
What are you trying to do? What error do you get?
I have the same virtual device and it works for me (set brightness of Philips Hue bulb).
    Thank you j.nowacki and cafun
    Sorry for my bad expression , all i want is how to see lua code in screen.
    do i need to trigger the device first and press something button in screen ?
    chinastar89, do you mean that you do not see place to write your code? I assume you have HC2, since HCL does not have LUA. First add a button to your device - tick the check box next to single button image and add it. Now save. Go to advanced tab of your virtual device. Scroll down and you will see place to write your code in.
    And if you want to learn more about Lua, Start with creating block scenes and switch to the Lua view. You then see what it's doing.
