on the weekend I mounted two of the 2x1,5kw Fibaro Relay Switches in my Closet, I installed two, because I already had the necessary connection etc.
I also installed a Wall-Remote, and paired everything. When clicking the Wall-Switch the two relays are switched on.
Now, I would also like to do something like this from the IOs App.
My thought was: Group the two relays thus, when one gets switched on, the other one would also be switched.
But it somehow doesnt work like this.
Can someone give me a hint?
Cheers
joystick
Cheers
joystick
I would create a scene which is triggered on the state of the devices. When a change is detected, i would set the value of the other relay.
But, you will need to have a small delay at the end of the script, and a single-run check at the beginning, else they would start to flap.
    First of all: Thank you!
    Your solution was something I was thinking about aswell, I was just wondering why the Grouping would not work in this case?
    Cheers
    joystick
    Joystick, do mean associations by Grouping?
    Correct
    Joystick, it will not work correct, since associations work only when device is controlled with button, not from interface or scene.
