Can the NOT operator be added please. I'm using the HC Lite, so no LUA. For example. I have a variable which shows if someone is at home (My wife is on windows Phone, so no support there). Using the motion sensors the HCL reports if someone is home, sleeping or away. When everyone is away, I don't want my heating on, but in the other two situations I do.
Ergo: Away and NOT(Away). Now I have to use: (home or sleeping) and away
I also have other variables with more values.
PLEASE add NOT
Why dont you use Variable "You Home" to 1 if you are home and 0 if your not. so as "Wife Home" to 1 and 0. Then if both are 0, none are home.
rarev, operator NOT (~=) is added in version 4.x there will be a special option like "not equal"
