Update HC2 4.019 BETA
Fibaro Home Center 2 v 4.019 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
Known Issues
- Breached sensoer with Arm Delay causes instant alarm after being armed
- Data range selection in event panel doesn't work properly
- For devices imported via Gateway Connection may have no icons
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
Known Issues:
- Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
- Important! Remote access is NOT available for this version.
- Gateway Connection - status of dead device between master and slave controller may be different
- Devices not properly configured on 3.X may not be converted properly
- Reconfiguration may not work properly in some cases
- On mobile clients devices may be visible in different categories than configured
- Advanced settings for some imported devices may not work properly
- Plugin for Sony TV will not work with newest Sony Firmware
- Event Panel- some issues with scrolling
- LUA functions fibaro:log("") i fibaro:call(id, "setproperty", "") may have some issues
- Horstmann Switch HRT4-ASR-ZW is not fully supported
- Horstmann Thermostat HRT4-ZW- higher battery usage and incorrect reports in some cases
- Doorlocks- some functions may not work properly
- Thermostats Setpoint- are not fully supported
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 88
  • Created
  • Last Reply
Update not yet available for me, is the update rolled out in phases ?
Is this 4.018 know issue solved ?
Known Issues:
Thanks for this update.
one IMPORTANT note: Starting the update on the interface is showing a web-page without any info and progress. As i had same problems with update before, i have manually opened one time
of HC2, after this it is showing the update progress. This could be important for users, not seeing any progress and hard-rebooting the box / while the update and files are tried to be copied in background.
So if your box is hanging or if you don't see any progress, reload or better enter only
(with ip of your box) and you will see whats going on.
After rebooting, since now everything is ok, dead battery devices are ONLINE again,
[ Added: 2014-11-26, 22:25 ]
Hmm, was pleased to early, now 2 "eyes" are dead, will wait till tomorrow, hope dead devices go online again, will report it here
I am not going to sing your praises "far from it" BUT
4.019 is not to bad here... silly bugs exist still but important silly bugs have been resolved!
One question!
What browser, what phone do you guys use to test against for simple things like fonts etc to go astray? seems like a stupid question but just fail to understand how the formatting on plugins can be so bad can only assume its resolution issues on devices!
Guest David R
Still no icons...and unable to add icons
Still unable to change Parameters in battery powered devices. See screenshot.
In 4.017 someone from Fibaro said the parameter is only strange until device has reported back. We'll I have waited for hours.,
One question!
Wonky CSS and layouts sounds like a good use case for running Wraith before each beta release is made public for testing.
So far no dead devices
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Excellent job, any idea for when #0001919 will be fixed?
Mine is online.
Don't see much change yet expect for the small fixes indeed.
Still quite some bugs. The first one is that the alarm panel still shows nothing for any devices.
Still dead nodes of devices that are indeed not dead.
Checksum of Recovery failed..?! What is corrupted? and what is the difference between recovery and restoring a backup?
How is the support for Qubino devices (I am thinking of the temp sensor on the Qubino devices, the temp sensor will add great control of how hot the device will be during use and an easy ande secure way to monitor all dimmers/switches from Qubino - would be nice if Fibaro added this...)?
Thanks for this release Fibaro.
This update appears to be exactly what was required, bugfix bugfix bugfix .. a couple more of these type of releases without adding too many new things and preferably without introducing too many others, & we'll have a new stable !?!
It would be nice to know if previously known issues have been closed out though, you may have updated bugtracker, I'll check tonight when I get home. Keep it up, trickling out bug fixes only is likely to be a perfect scenario for a lot of users ....
cheers,
al.
Now i have NO Z-Wave communication AT ALL Anymore.... will leave it "rest"/running over the night and see what happens tomorrow.
Update: Z-Wave Communication is finally "back" again... after about 50 Minutes.
EzMotion 3 in 1 Sensors still not working.
48 dead devices, 5 alive.
Great update.
I've entered my 4 issues with the beta in
I hope some of you will follow suit.
All battery devices are currenty shown as dead in interface, except smoke detectors.
Will try to reboot machine and see.
is it possible that this is only a false state on the web-site?
yuzo, yes it is possible
OK
I have updated from 3.590
everything went smooth except one thing
1) My satel Alarm says : Attention, integration with the alarm control panel is not fully configured. The control panel does not have a alarm partition named Fibaro.
when i try to reload configuration it does nothing
Update:
Z-Wave communication is more or less working after a reboot... but only for about 5 Minutes... after that, the complete Z-Wave Communication Stops / is not working at All.
I've let it rest during the night... but in the morning/today: still no Z-wave Communications.
so the Situation is much worse than with the previous Beta.
I do have some Dead Devices (two 3 in 1 Ez Motions now not just don't work anymore.. they are also marked as dead)
What could be the Problem / Solution ? Any Diagnostic Information available ?
Thanks fibaro for the z-wave fix. First time since the first alpha the dimmers that are controlled through association are finally reporting back to the hc again.
Guest MikeGooder
Updated from 3.590 and it all went smoothly.
Only real issues for me on this version are
Battery devices showing dead, never had a dead node before on 3.590
Horstmann Boiler switch does not work.
Couldn't try it for long because of the boiler switch not working and its cold at the moment
/emoticons/default_icon_smile.gif" alt=":-)" /> , but looks like its getting close for me to use
Cheers
Mike
