Update HC2 4.019 BETA
Fibaro Home Center 2 v 4.019 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
Known Issues
- Breached sensoer with Arm Delay causes instant alarm after being armed
- Data range selection in event panel doesn't work properly
- For devices imported via Gateway Connection may have no icons
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
Known Issues:
- Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
- Important! Remote access is NOT available for this version.
- Gateway Connection - status of dead device between master and slave controller may be different
- Devices not properly configured on 3.X may not be converted properly
- Reconfiguration may not work properly in some cases
- On mobile clients devices may be visible in different categories than configured
- Advanced settings for some imported devices may not work properly
- Plugin for Sony TV will not work with newest Sony Firmware
- Event Panel- some issues with scrolling
- LUA functions fibaro:log("") i fibaro:call(id, "setproperty", "") may have some issues
- Horstmann Switch HRT4-ASR-ZW is not fully supported
- Horstmann Thermostat HRT4-ZW- higher battery usage and incorrect reports in some cases
- Doorlocks- some functions may not work properly
- Thermostats Setpoint- are not fully supported
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 88
  • Created
  • Last Reply
Couldn't try it for long because of the boiler switch not working and its cold at the moment
/emoticons/default_icon_smile.gif" alt=":-)" /> , but looks like its getting close for me to use
Cheers
Mike
Oh well won't bother with this release then!....another beta bites the dust for me!
stevenvd -> Posted: 2014-10-30, 10:38
Fibaro, can you confirm why / if there is a problem in the alarm panel and if it will be addressed?
________________________
A.Socha, FIBARO developer Team -> Posted: 2014-10-30, 10:48
stevenvd, we know about problem, with 4.019 it will be fixed
Noup... Fibaro you did not fixed this with 4.019
Well, don't know exactlly by where to start... The update went well, with my configuration the conversion phase was better then old beta versions, but I start fom a fresh install in 3.590 with around 65 modules.
At the begining everything seams to be ok, but after few hour almost all modules stop responding, they don't just appear dead, but they are. try restarting the box but still same issues after few hours.
In my case the interface look to be more reactive then previous version. Looks promising but today not really usable. Danfoss are still dead, sometimes (very often) fals dead nodes with battery modules, still the bug (12344454453) with FGMS, lot of real dead nodes, fals triggers with fgms probably due to lost of communication, sitll impossible to amend a scene after a module conversion changing it ID, still no energy consumption (not on the bugfix list) and a few minor thing in my case.
I'll raise some tickets tomorrow, for the few bugs that haven't been discussed yet, and will go back to 3.590 just after.
If somebody from Fibaro wants to have a look to my box before the restore, just let me know.
Guest Lode
Same crap....dead nodes, sensors don't work, do i need to go on ?
Everything is working fine, only one battery device going dead sometimes, but its quite far away.
In my situation, scene activation on Fib dimmer (10 pcs) stopped working... But reconfigure + fix parameters & associations solved that. Then I had to change many scripts because of the new IDs.
But then it looked good say 99% OK, except for one obvious thing: any node CAN and WILL turn dead. Not everybody has this problem, I think. I have no clue why some people say their "dead node" problem was solved by 4.X - while I think it's the opposite
For me also 4.019 fixed dead node problem with battery operated devices. I installed update yesterday, woke up dead devices and these which are acutally working, are now still working flawlessly. And those who are really dead (batteries out etc) these are again dead.
Havent got time to test other things yet.
All of my devices disappeared after upgrading to this beta.
I cant understand how you can continoue on this track......fail after fail after fail.
I think I talk for alot of people in here when I say that your development skills are not in a topclass.
Seems to be working very well after a day, no dead nodes at all!
everything is working, behalve :
CO2 Sensors Siegenia Aubi :no datas
Energy monitor 2 clamps : no refresh of consommation
battery devices are not dead anymore (if they are i can wake them up)
but now every time more and more fibaro switches and dimmers are going dead, witch is pretty annoying because i can't dim my lights anymore except from scene's
OK
I have updated from 3.590
everything went smooth except one thing
1) My satel Alarm says : Attention, integration with the alarm control panel is not fully configured. The control panel does not have a alarm partition named Fibaro.
when i try to reload configuration it does nothing
Exactly the same problem I had in 4.018.....obviously Fibaro partition is present.
Fibaro team, any news on this?
OK
i have even tried to delete the plugin but it does not get deleted....
only thing that does is put all my satel sensors back to unassigned
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> :(
Guest David R
Time based scenes no longer work. Going to a HC2 reset and hope that works. No dead nodes yet though
Yes, Yes Yes......I am so happy. The whole z-wave enigen overhalul has been great.
My Fibaro ghost is back. HC2 is switching devices on again whitout any local or hc2 action.
Before anybody is going to sheep about this is beta and go back to stable please look at this post:
and this post
Well, I have had quite a lot of patience with Fibaro. I have loads of dimmers, water sensors, switches, door sensors and plugs. The road has been quite bumpy since I first got my HC2, but it has always improved. Well, 4.17 wasn't that much of an improvement when all Danfoss radiator controllers died, but anyhow. Today I decided to updated to 4.19. Maybe it would fix all the dead battery nodes, I thought. I shouldn't have done that. The updater stopped at 0% for more than two hours. I tried to reconnect. I have now tried to restart. No ip adress and therefor no connection. I guess my HC2 is bricked. God I hate Fibaro. I have spent about 2k EUR in Fibaro equipment and now I have a dead house. I have always thought that the people complaining and making fun och Fibaro in these threads (hey, I even blocked deanperry or whatever he is called) but now I actually am fed up. An upgrade from beta 4.018 to beta 4.019 should not, in any way, shape or form cause a complete failure. Then you really should work with software development at all.
I feel your pain biggles, i saw the light a few months back, this beta testing seems to be going backwards. The level of discrepency between it working for some and complete rubbish for others is the most frightening bit.
It's really sad to see that we have come so far that we actually regard "going dead sometimes" as a good thing. With any other solution it would be completely unacceptable.
Has Fibaro even admitted that there is a problem with dead devices yet? Or is it still our own fault? The youtube movie that was posted the other day (
) showing a "dead" motion sensor that reacts to motion, is still not enough proof that something is wrong?
As long as Fibaro continues to ignore this I don't see that we're going to get any improvement any time soon.
I uploaded myself the last Fw 4,019. I detect the same drawbacks of many dead sensor. I don't understand how you don't handle thermostat yet Secure in the SRT322 in the SCS318-have not yet realized that winter has arrived. I am ordering the new controller VeraEdge. Goodbye Fibaro.
The video was from me, and yes, It has been acknowledged in the bug tracker. Bugs 2087/2095
