VD Slider Scale
Hi ,
I need to change sliders Full Scale so I can use them in a VD to adjust temperature values.
Is there any way to have a decimal point resolution?
Does anyone has experience on this issue?
I'm on HC2 3.590
4 answers to this question
I would like this feature were much.
I have a slider for my tv that controls the volume 0 to 100% and the tv has 0 to 60 in volume setting so its the same thing but different.
A quick workaround for you could be to have 0-100% represent your minimun and maximum temperatures.
Ex temperatures = 15 minimum and 25 maximum.
Then have a label below that changes with the slider.
Divide 100 / (25-15) = 0.1 degrees per % of the slider.
In GUI:
Slider: Temeperature at 50%
Label below: Current setting: XX,X Temp.
anonymous66, you should just read the value from slider and multiply it by some factor that will give you desired resolution.
    Nowacki I know that but , from the user's point of view (VD visualization), see a number on the right that doesn't rappresent the value of the scaled variable isn't correct.
    Is there any way to change it by LUA code?
    anonymous66, not in current firmware, sorry.
