xantony 0
i am starting with HC2 since few weeks, now i am trying to set up an alarm system. actually i have 12 door sensors and 8 motion sensors (all fibaro) for my alarm system.
Since i am with version 3.59 ( stable to me and not going to any beta untill everything works fine with 4.X versions) i started with tha alarm panel which is somehow limited for my need.
i would like to have something modular, like have 2 main alarms : one just perimetral ( just door sensors ) for being protected during the night with my presence at home; the other one volumetric+perimetral ( all the sensors active ) when i am away.
moreover i would be helpful to divide the zones of the house to be alarmed indipendently.
I did one easy try using the standard panel but it's very limited, also i found out that on the phone application there is no way to arm with one button the complete alarm system, i had to go room by room, device by device and arm them. is this as it was supposed to or i am missing somethin? how did you set up the alarm according to your need?
scenes might help but i am not into lua yet and i would start possibly with block scenes.
i would appreciate your suggestion and advices on this topic, also because i have 3 sirens that i did not installed yet cause i am scared doing somthing wrong and wake up all the building during the night
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />antonio
13 answers to this question
