Hi All,
I have been trying to install the ShutterRoller relay for my garage Door without success. I tried all the wiring combinations without success.
My garage door works only with remote control (no fixed button) and I have been able to open/suspend/close the door using the Relay switch but not the ShutterRoller Relay.
Anyone can send me a wiring diagram on how to install the shutterroller, the one from the paper comes with the relay not working!
Thanks in advance
HY.
hyaman, Roller Shutter will not work with any external motor controller, it should be used with plain 230V AC single phase motors. Relay Switch was working probably because it was connected to some kind of relay input of your controller.
