kmeta 2
Hello i make Virtual device with 2 buttons.
If you press 1-st i send HTTP command ON to remote device with 2-nd i send OFF
The problem is when i change the IP address of the remote device i should to change IP address in the 2 buttons.
How i can set the IP address of remote device only in one place ?
i try to set in main loop but don't work.
