Update HC2 4.021 BETA
Fibaro Home Center 2 v 4.021 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.021:
Resolved Issues:
#0001844 HRT4-ZW and ASR-ZW not working, causing the heating system to burn continously
#0002026 SSR-303 not properly recognize
#0001958 After recovering backup all devices where online. Now all battery devices has become dead
#0002095 After upgrade V3 to 4.019 random dead nodes appear
#0002087 Nodes marked as dead, but functioning.
#0002036 Wrong spelling in Delete Device window: "Learing" instead of "Learning"
#0002139 4.020 Horstmann hrt4 can not set association
incorrect values returned by fibaro:getValue (LUA)
Horstmann Thermostat HRT4-ZW does not save the association
Many other minor fixes
Known issues:
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Important! Remote access is NOT available for this version.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Backup from 4.018 should not be visible as compatible with 4.019 or newer. Restoring backup 4.018 on 4.019 or newer will cause with no access to all backups, however backups are safe and can be restored after recovery or installing new version.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
4.020:
New Features:
Pre-Update Confirmation - installing update on 4.020 or newer will prompt user additional confirmation.
Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
Fixed Issues:
Incidental marking devices as dead
Horstmann Devices support
Many other Z-Wave engine fixes
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 147
  • Created
  • Last Reply
Andrew, is there a let's ignore anything that steven says or askes rule within fibaro?
Guest David R
Andrew this does not work what you said?
nope, you are not the only one.
the same rule also effects me
Hi Fibaro and forum users!
I have tested out the beta now and for the two or three latest beta-versions I had this problem:
- If I go to configuration->z-wave network and want to change the option the "device polling interval" and/or the option "do not mark nodes as dead" the changes are not saved after pressing the save button on the right hand side.
Hi, It's on bugzilla...and acknowledged I think.
Cheers,
Al
Try to change parameter for my Aeon 4in1 : seems that does not work.
The page display old value and a text with "last set value :" with the new value.
So seems that Aeon does not receive new value (even I wake up it manually)
[ Added: 2014-12-09, 13:32 ]
Update : after few retry with save and manual wakeup .... my HC2 hangs with zwave.
ZWAVE led stay ON and no zwave activity at all. Need to restart it.
84 hour without freeze with 4.021
Bye
[ Added: 2014-12-09, 13:36 ]
Update 2 :
After restart of HC2 try again.
Still no update on zwave parameter value.
Manual wakeup does not help , even I can see "routing table update" on the log box !!!!
Guest David R
This is similar issue with fibaro motion sensor. Sometimes says "last set value" but does nothing?!
@Fibaro: NOTHING is working for me atm.
After a reboot, I can send commands for a very short time (about one minute). Afterwards, NOTHING is happening anymore. No matter how long I wait or how often I click, no command will be sent to the device. After a reboot, I can quickly control everything for about one minute again.
Please advice. I'd like to prevent downgrading as I seem to be the only person with this issue, however I won't be able to stay in this situation for long because I can't control my lights in the whole house without the HC2.
Please comment if you want to check via remote access or if I should just revert to an older version.
candrea77, press 3 times b buttons (fgms should glow on blue - then he is awake)
My sensor is Aeotec 4in1 not the Fibaro one ..... I've tried to wake up it in all way I know ... but nothing to do (please note that with 3.590 manual wake up work with no problem). Seems a bug of 4.021.
Cheers,
Al
Thanks Al!
I found it and added a comment. The "device polling interval" problem is a bigger problem for me. Really want to set a bigger value but I can't...
Do you have the same problem?
-Andreas
Good news,
ZXT-120 works well, shows the temperature from the included sensor, you can select cooling, heating mode, temp setup, ventilation speed.
One small problem on batery mode: with new batteries it shows Low battery level on top of the HC2 interface.
I have test it on an LG air conditioner.
I had a lot of dead nodes, so I clicked on reconfigure zwave network. 16 hours later, its not configured, and most of the devices (fibaro 2 x 1.5k switches) are now showing as additional new devices.
Worse still, the light switches dont even appear to work physically anymore, via the software or pressing the switch.
My wife's not overly happy.
[ Added: 2014-12-10, 09:43 ]
Sorry to post twice in a row, but the Checksum feature on the back screen. Mine says it is corrupted. Have recalculated several times, does this mean I cant go through the restore process?
(...) so I clicked on reconfigure zwave network. 16 hours later, its not configured, and most of the devices (fibaro 2 x 1.5k switches) are now showing as additional new devices.?
I reported a bug for this... I'm sorry you didn't read it before clicking 'reconfigure'. I understand, I didn't have the habit of checking bugzilla either, but now I do! There are many features/bugs in these betas. See bugzilla, "0002177: Please explain the use of "reconfigure"". Mr Socha answered that indeed new id's and new devices sometimes appear, but not always. Please read his explanation in full.
I'm sorry I can not help you with the checksum error... Maybe too obvious, but have you tried [email protected]?
In fact... You have two diffent options... Restore the last backup, before the 'reconfigure incident', on the current 4.X firmware. Or do a full recovery with the last 3.X backup. I'd wait until I knew more about the checksum error. And I certainly would go for the 3.X option if Fibaro gave me a 'green light'
For the physical control problem.. Have you tried to power off your HC2 and then the modules, then only power on the modules. I have had this happen a few weeks ago, and it did solve my problem on a 2*1.5 relay.
Thanks Peter for your responses. Tbh, I usually do read what others have reported - but I missed this one!
I'll try power off the house to see if it helps, when i get home.
As for the checksum, I'll wait and see what the response is on here. I think the HC2 configuration is so messed up, that I think rebuilding from scratch might be the best course of action. I just need to know if i restore, I'll go back to version 1.4 ok.
It means there is a risk recovery will not work, Yes.
All I want for Christmas is .022
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> with power metering working
/emoticons/default_icon_wink.gif" alt=";-)" /> connected up the aeon heavty duty switch and relays for cooker hob and lights so when oven => 50watts then enable cooked hood extractor and if lux < 50 then switch lights on as well we cannot cook in the dark can we
excuse the full quote.
I really wonder how Fibaro can comment directly after this post, apparently without even taking notice of it. Fibaro support suggested that I'll just revert to an older version. Without even asking for any kind of investigation. I also wonder how Fibaro is supposed to find bugs if they don't even have a look at the issues the customers are facing.
Anyhow:
I tried to go back, but the HC2 won't boot into recovery. After holding the "+" button after turning it on it will just stop with all leds lit.
I need this thing to work, so I hooked it up to my tv:
what I get when booting the recovery:
screenshot after booting into the normal operation mode:
as you can see, crond won't start.
I hope Fibaro will answer to this post. I really think it should could be an easy fix if someone would connect to my box and have a look...
Guest David R
Is it a known bug in V4 that timed based scenes need manually restarting after Fibaro alarm has been activated and reset?
Interesting.. 4.022 is out.. and still no new thread?
Congrats!
