rtripa 1
I have a solar water heater, where I have a 2kw resistor for those days without sun. Also have a tamp probe on it. I have added a 3kw switch and a UBS to read the temperature. All is working fine.
However, I tried to create a scene unsing the blocks (LUA coding is still a bit... difficult!
/emoticons/default_icon_rolleyes.gif" alt=":roll:" /> ), which should do something like this:IF, water temperature <40C AND if resistor is off AND door is opened, THEN send push notifications.
I've attached the scene.
The problem is that as soon as I press "Run", I immediately get a notification, even if the door isn't opened. What can I be doing wrong?
Rui
